Re: Saddle (Pull Rod) Type Starter
Posted by gene bender on December 18, 2010 at 11:59:40 from (67.55.227.196):
In Reply to: Saddle (Pull Rod) Type Starter posted by Faster346 on December 16, 2010 at 20:07:52:
Wont the starter from the C fit and work. Then if it works you can get a starter for a C then install it and you will have the pull rod set-up. You need the starter with the button for the saddle type. If your M was drilled and tapped for the saddle sw you could have the stud replaced with the button but yourM starter isnt drilled and tapped for the saddle sw.
