Re: super H sterring
Posted by Bob M on December 18, 2010 at 15:04:16 from (67.240.171.41):
In Reply to: super H sterring posted by pblack on December 18, 2010 at 14:57:19:
Most likely is worn pivot shaft bushings - especially the upper bushing (it's the the one directly under the sector gear in the steering box).
If there's an radial play in the pivot shaft the bushing must be replaced.
Fortunately it's cheap and relatively straightforward to install a new bushing (been there, done that!)
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
