Re: What is the Attraction?
Posted by Darald in Az on December 18, 2010 at 15:12:23 from (74.47.106.123):
In Reply to: Re: What is the Attraction? posted by Stephen McCoy on December 18, 2010 at 06:36:33:
Tell us more about this beautifully done crawler. Steering is my question, did you split the tractor ahead of the diff and use the T 20 clutches or???. How did you couple up the drive line if you split the diff off of the H? The photo looks like the H is intact.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
