I think the ST225B is OK. My parts CD says ST225 BT. For what it's worth, the M and H have the same bearing on the worm shaft. If there is any play at all in the worm shaft bearing, you should replace it as it is cheap and any play results in play in the steering. The bearing inner race must be clamped tight to the shoulder on the shaft with the castle nut on the end of the shaft. The outer race of the bearing has to be clamped tight in the steering box by the big hex plug on the front of the steering box. I've had to put a machine washer in there sometimes to get the plug to clamp the outer race. If you use a washer just make sure that it contacts only the plug and the outer bearing race.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
