Re: 354 fuel bowl
Posted by Jimb2 on December 18, 2010 at 17:13:07 from (99.240.236.11):
In Reply to: Re: 354 fuel bowl posted by steven in tn on December 18, 2010 at 17:00:03:
Hi, I would not recommending bypassing a Diesel fuel filter and installing an inline gas type filter.
The present filter is designed so any collected water will collect in the bottom of the glass bowl and can be drained off. One drop of water in an injection pump is many $$ to repair.
Jim
