Lift All Rebuild
Posted by sflem849 on December 18, 2010 at 18:38:06 from (69.197.84.192):
I pulled the belly pump from my MD for the clutch split and I go to thinking about giving the Lift All some help.
It doesn't have a whole lot of lift in it anymore. It won't lift my 13' JD disc all the way up w/o putting the tractor in reverse. I am also sure it has a couple leaks, but everything else leaks enough you can't tell which seal might leak.
Is there a rebuild kit available or do you have to piece the gaskets together? Did I read something about shimming the pump to bring it back to life? Is there anything else I should do to it while it is out?
