just looking at your pics again and have a question.
I see the PTO shaft running through your differential... same set up as my 434. If I reach in and try to wiggle the front end of that shaft (with PTO lever disengaged), I get all kinds of play... like 1/8" to 3/16". I pulled the shaft out and see there is just a pin on one shaft fitting into a hole on the other - steel on steel. no bearing, no bushing, etc.
With PTO lever engaged, the collar lines up the shafts and all play is gone.
With PTO disengaged, do you feel a lot of play in the front of the shaft?
It seems like a bad design... should keep the PTO engaged as much as possible to minimize the steel on steel rotation between the shafts.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
