You need to make a sketch where your rotor is pointing on the mag before you remove it, then when installing the distributor rotate the rotor to the same position as in your sketch and install it. Hal PS: You can also convert your mag to a distributor by using an auto type coil and using the points in the mag. The mag's coil wire needs to be disconnected at the points. You need to disconnect the kill switch that grounds the points on the mag. You would need an ignition switch with battery voltage fed to it and then fed to the coil. If the battery is negative grounded the wire from the switch is connected to the + terminal on the coil and another wire from neg terminal to your points. You may need a ballast resistor between your ignition switch and coil on either setups.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
