Farmall 350 Tachometer
Posted by WI-Ed on December 19, 2010 at 07:41:49 from (216.41.196.34):
The tachometer on my Farmall 350 doesn't work. The cable seems to be okay. I took the tachometer off and put a drill to it and it moves. Where else should I look to see what is causing my problem? Was there any common problems with these tachometers?
