Re: M belts
Posted by The Red on July 04, 2000 at 06:41:08 from (12.75.197.222):
In Reply to: M belts posted by Pete on July 04, 2000 at 06:29:57:
If you are replacing both belts, simply cut the two old ones off to save time. The front flange on the water pump has an adjustment screw. I usually take the whole screw out and then tap on the flange to adjust. It is threaded. Use lots of penetrating oil. You can crack those fairly easily. You will have to install the generator belt first then the main belt.
Post A Followup
: Re: Re: M belts
