On the back of the switch is a bigger wire of open coil thats the light dim resistor and theres one of smaller wire wound around a flat piece thats the field circuit resistor. It should be around 3 ohms but if its open/bad she wont charge in the Low charge switch position.
The switch must be grounded ok as needed otherwise she wont charge at all.
If that resistor is bad/open you can just replace/repair it or the whole switch. You may also look at the switches connections as some may be bad/corroded.
The wire up from FLD on the genny goes to that switch and gets its ground, its direct to ground in hich charge but in Lo it passes thru that resistir then to ground.
CHECK FOR A BAD/OPEN FIELD RESISITR ON BACK OF SWITCH AND CHECK SWITCH CONNECTIONS
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
