Re: 350 TA
Posted by Janicholson on December 19, 2010 at 14:50:15 from (67.72.98.45):
In Reply to: 350 TA posted by Farmall Dann on December 19, 2010 at 09:36:55:
The solution is to get the differential and trans warm (heat lamps and or electric heaters Kerosine is also good) then drain the two plugs just enough to let all water out. It is filled with Hytran, so don't drive it around or it will mix and be a milky mess. Jim
