Re: 826 German main bearings
Posted by Owen Aaland on December 19, 2010 at 17:49:10 from (198.70.47.181):
In Reply to: 826 German main bearings posted by ihjasonj on December 19, 2010 at 09:13:50:
According to the procedure manual you should not have to split the tractor to replace the main bearings.
As per the IH service procedure manual, Operation number 4-146-D.
826 Tractor Diesel engine.
CONNECTING ROD AND MAIN BEARINGS
- Replace
1. Drain engine oil.
2. Remove:
o Oil pan.
o Rod caps and bearings.
o Main caps and bearings.
3. Check crankshaft to GSS-1377 for specifications.
4. Install new bearings and check with plastigage.
5. Reassemble.
Flat rate time is 8.8 hours.
