Re: Diesel cracked head????
Posted by Janicholson on December 19, 2010 at 20:06:06 from (67.72.98.45):
In Reply to: Diesel cracked head???? posted by plow hand on December 19, 2010 at 15:53:43:
Letting it run on gasoline for 2 minutes, then switching should have less than 15 seconds of missing on diesel. If it is switched over too early it will show some white smoke. If it is rich on the gas operation, it will be gray white looking diesel misfiring. If it takes 30 seconds to two minutes to clear up, it could have a poor injector pattern, or poor compression. A compression test and leak down test can be made on the gasoline operation to assess differences between cylinders.
Finding the cylinder that leaks can be easily determined with a hand held infrared digital meter. Good luck. Jim
