Posted by Janicholson on December 19, 2010 at 20:22:33 from (67.72.98.45):
In Reply to: Pump fuel posted by Bud Kaiser on December 19, 2010 at 07:36:15:
Slow running engines cannot use either advanced timing or as much high compression as 6000 rpm car engines. The flame front travels at a speed that can cause spark knock easily. With good gasket placement to avoid hot ignition points, a cold spark plug, and 101 LL av gas, I imagine an 8.5 or 9:1 CR would be doable for pulling only. Just a guess, as reality trumps theory. A three main bearing 4 cyl non dynamically balanced assembly will not live at high enough Rs to do 10:1 (opinion) Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
