Posted by tempola on December 20, 2010 at 04:42:05 from (75.120.185.15):
In Reply to: Changing Rear Tires posted by Matt Weltz on December 20, 2010 at 04:22:37:
sometimes you can break the bead by placing the tire and rim under a tractor draw bar, or large truck, and place the foot of a lift all farm jack on the tire next to the rim. jack it up to place some pressure on it. and get out your sledge hammer.
if it breaks loose, flip over the rim and repeat.
More often than not, the inside rim has rusted, firmly holding the tire in place. if this is the case, you may not be able to save the tubes. a very stubborn tire will have to be cut open enough, (I use a chain saw) to get to the inner bead. I then cut the inner beads open from the inside with a die grinder, through all the wires. once the bead splits open, the tire will practically fall off.
once the tire is off, grind the old rust off. if you dont, the new tire will not want to come all the way out against the outer flanges. I usually use lots of dish soap and slick it up.
I would use new tubes. it's just too much work to have to redo the job!
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
