Re: Changing Rear Tires
Posted by glennster on December 20, 2010 at 04:51:06 from (99.90.9.153):
In Reply to: Changing Rear Tires posted by Matt Weltz on December 20, 2010 at 04:22:37:
i use a handyman jack and a log chain wrapped around the tire. you have to be careful so the jack doesnt slip, the foot of the jack will push the bead down. squirt some soapy water in there to help lube the bead a little to get er to pop off. if the tire is real old and stuck to the rim, get a cup full of gasoline, lay the tire flat and pour the gas around the bead area. let it set over nite. the gas will soften the rubber and make it easier to get the bead off.
