With a Delco, I use 3 Amp, 1000 PIV diodes (1N5408) which are WAY overkill, but I've never had a failure, as opposed to using, say a 1 Amp, 100 PIV diode which WILL occasionally fail, apparently from voltage or current spikes.
I buy the 1N5408 iodes in bulk, typically for about $.05 so "overkill" doesn't cost much here!
The PIV (Peak Inverse Volts) rating has to do with the highest reverse voltage spikes the diode can live through, in general, the higher the better, at any rate you'll want to be WELL above 12 Volts.
The AMP rating is the amount of current the diode can handle in the forward direction, when exciting the alternator, which can take perhaps around 2 Amps.
NO reason a similar diode wouldn't work with about ANY internally-regulated alternator.
For a (-) grounded system, the CATHODE (white-banded) end goes to the alternator, as shown here with a Delco alternator.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
