Re: Another governor problem
Posted by The Red on July 04, 2000 at 10:39:56 from (12.75.196.153):
In Reply to: Another governor problem posted by Fudd on July 04, 2000 at 10:34:41:
Fudd pop off the spring and check the thruster bearing assembly behind the spring. It should slide horizontally on the shaft but not wiggle on the shaft. If it does, then the bearing assembly is worn. If it is not wiggling, then a new spring would be the next step. If the thruster bearing is bad, talk to your banker first. $65 for the assembly on my last H.
Post A Followup
: Re: Re: Another governor problem
