Re: T/A in forward position-is that direct drive? Other ?'s
Posted by todd hamilton on December 20, 2010 at 11:23:19 from (174.252.189.110):
In Reply to: T/A in forward position-is that direct drive? Other ?'s posted by curt in ky on December 20, 2010 at 07:43:47:
We ran my cousin's 886 like this for years. You don't need a t/a unless you are pulling a moldboard plow. Forward is high range direct drive. Check the engine oil and antifreeze carefully as internal corrosion from electrolysis is a problem with this series tractor.
