Re: Just bought a 12v Conversion...coil?
Posted by Bob on December 20, 2010 at 11:37:27 from (69.178.228.68):
In Reply to: Just bought a 12v Conversion...coil? posted by Faster346 on December 20, 2010 at 11:26:21:
The secret is to limit primary ignition current to the range of 3.5 to a little over 4 Amps, (points CLOSED engine stopped, ignition switch "on") to prevent overworking the points so they quickly burn and/or overheating the coil.
The CORRECT combination of the original 6-Volt coil AND external ballast resistor with the proper value will achieve this and even allow for a "starting bypass circuit" to give full voltage to the coil for cranking, if desired.
OR, a "true" 12 Volt coil that needs NO ballast resistor will work, instead. (NAPA IC14SB, for example.)
