Posted by TractormanNC on December 20, 2010 at 14:06:50 from (72.251.105.57):
In Reply to: Touch control posted by Farmall-H on December 20, 2010 at 11:06:28:
Check under the front of the TC unit to make sure the feedback or canceling linkage is connected, free and working. This linkage returns the spool valve to neutral when the rockshaft has moved to the position that corresponds to the position you have set the lever. In other words, the spool valve has to know the position of the rockshaft and the manual lever in order to return the spool to neutral at the proper position of the rockshaft.
With all due respect to Gene, I would use Hy-tran or a good universal tractor hydraulic fluin in the TC.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
