Re: T/A in forward position-is that direct drive? Other ?'s
Posted by pete 23 on December 20, 2010 at 16:06:15 from (184.12.34.48):
In Reply to: T/A in forward position-is that direct drive? Other ?'s posted by curt in ky on December 20, 2010 at 07:43:47:
There are a jillion hydraulic TA's running with low side out for years. It all depends on what is causing the TA to be out. If worn out sprag and pressures are good, including lube pressure you won't hurt a thing. On the other hand if it failed because of internal leakages, accompanied by low lube pressure you would be taking a chance running in direct only. Not likely though. Far as ta being stuck, those cables stick and break off just like throttle cables. You can always unhook linkage at the selector spool and pull spool up to check for low ta drive.
