Re: cold weather starting
Posted by Brian2 on December 21, 2010 at 18:57:11 from (74.14.20.90):
In Reply to: cold weather starting posted by todd heck on December 21, 2010 at 12:08:33:
My Super A has no trouble starting in temp way below zero (could be -20). I have the original 6 volt system. As others have mentioned, I always turn off the gas. Years ago someone on here mentioned that if you don"t move the thottle position when you start it seems to help. Well, over the years I"ve adopted it out of habbit, and I"ve never not had it start. It should fire up like your other one. Since we"re on the topic of cold etc. The only time I had a issue with the tractor is when I left it too long to warm up, I ended up fouling a plug-so try to avoid.
Good luck !
