Re: 4130 Skid Steer
Posted by El Toro on December 22, 2010 at 04:14:09 from (108.3.200.96):
In Reply to: 4130 Skid Steer posted by sflem849 on December 21, 2010 at 18:40:10:
Which engine do you have? Hold your hand over the throat of the carburetor and see if there's much suction on your hand. It there's not much suction you probably need to do a compression check. You need good intake manifold vacuum to pull that fuel into the engine. Spray some of that carburetor cleaner where the intake manifold
is mated to your engine to see if the engine fires. Could be a bad gasket or loose bolts or nuts on the intake manifold. One other thing is you may have fire to your plugs, but is it firing at the right time as the engine may have jumped time? Hal
