On the coil side of the resistor you should be feeding full battery voltage while cranking. If your tractor doesn't have a solinoid(Ford type with 2 small terminals) just put a diode in the wire from the starter stud and the ign coil. The diode will feed cranking voltage(9 or 10 volts) but will prevent a drain back from ign to the starter when not cranking. Very simple circuit.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
