Re: 49 cub seal
Posted by sgtbull on December 22, 2010 at 21:39:40 from (163.191.228.254):
In Reply to: 49 cub seal posted by ericlb on December 22, 2010 at 11:48:07:
Chances ar good you have an old leather seal, and it needs replaced. Even in the oil level was high, if the seal was good, the leakage should not be so much as to affect your brakes. The quill that holds the seal can be removed without any consequences, but there are likely shims behind it, and a large rubber oring that seals the quill in the bore. Remove the three bolts and carefully begin working the quill out, starting with a stiff putty knife, andgraduating up in size to smaller pry bars, used carefully so as to not damage the shims or break the quill.
Once you have it out, any local bearing/seal supplier can match it easily.
