Re: Super C Just Quit!
Posted by El Toro on December 23, 2010 at 04:34:27 from (108.3.200.96):
In Reply to: Re: Super C Just Quit! posted by Loren in MN on December 22, 2010 at 20:58:09:
Use a volt meter set on DC volts and see if there's voltage on both small terminals on your coil. The points need to be open and your ignition switch on. Make sure your rotor is turning. Hal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
