On each side of the rockshaft againest the rear housing are cast pieces, the left one (near traction control handle) has the ear facing the inside rear tire for the 5/8 pin remove the pin from clevis on arm and move solid arm ahead & re-pin and the right one you slide the 1 1/8 pin from the whole adjustment arm thru it & install cotter pin or hitch clip. Two people or a jack will help cuz you have to hold & raise the hich at the same time. This locks the hitch at a set height (maybe 16-18") for using pull type implements. There are pics in the manual.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
