Re: Wheel spacing??
Posted by rustyfarmall on December 24, 2010 at 08:44:36 from (209.152.78.140):
In Reply to: Wheel spacing?? posted by outlet99 on December 23, 2010 at 16:32:58:
A 14" bottom will not plug up any quicker than a 16" in the same conditions and the reason is that NONE of these old plows have enough clearance between the moldboards and the beams. The newer plows DO have more clearance, but those do not work so well with the older tractors. If the amount of trash on the field is a problem, then you need to disc the field first and cut up some of that trash. That's how we always did it.
