Re: Cub Loboy rear light bracket
Posted by Jim Becker on December 24, 2010 at 11:15:42 from (173.74.120.16):
In Reply to: Cub Loboy rear light bracket posted by Dave H (MI) on December 23, 2010 at 15:40:43:
The light should end up slightly behind the seat frame. The slotted hole in the bracket may give you some range of adjustment in the light position. In any case, you may have to leave the light pointed a bit down (which you generally want anyway).
Quite a few guys have mounted the seat farther back than the original position. If you did that, you will probably have additional interference with the light. You may be able to make a modified version of the bracket in your picture to move the light back a little more and make it all fit. I suppose it would be possible to use a bracket to mount the light below the Fast-Hitch rockshaft. The light can be mounted bottom side up to simplify doing that.
I've never had a Lo-Boy with both Fast-Hitch and deluxe seat so I haven't faced this situation.
