Re: How to lock a fast hitch into place???
Posted by Mark Peters on December 24, 2010 at 11:19:47 from (66.222.5.4):
In Reply to: How to lock a fast hitch into place??? posted by gene bender on December 23, 2010 at 23:31:02:
If you`re talking about putting it at the fixed position (standard drawbar height) for PTO use ,you have to remove the 2 drawbar lift links from the rockshaft by removing the pin from the eyebolt in the rockshaft on the left side and the 1" ??? pin that sticks through the rockshaft (with leveling crank on it) on the right side.Both of these lift links then get attached to the rockshaft bearing plates that are bolted to the side of the transmission housing.There will be a tab on the left side that you slip the lift link over and insert pin. On the right side there will be a hole in the bearing plate pretty much in line with the rockshaft. Stick the 1" pin withe the leveling screw into this hole and insert cotter pin.That should do it.
