Re: SMTA FRONT TIEDOWN FOR HAULING
Posted by Russ from MN on December 25, 2010 at 15:47:12 from (68.235.68.3):
In Reply to: SMTA FRONT TIEDOWN FOR HAULING posted by Bud W on December 25, 2010 at 12:36:51:
I took some 3/8 x 2 x 5 and put 1 1/4 hole in one end and 3/4 in the other and bolted them to the tapped holes in the side. They are bent about 30 deg. so the pull is straight, I trust them and they stay on our C all the time.
