Re: Draining/replacing 706 Farmall Hydraulic oil.
Posted by Owen Aaland on December 26, 2010 at 00:43:35 from (65.165.246.90):
In Reply to: Draining/replacing 706 Farmall Hydraulic oil. posted by Handyman on December 24, 2010 at 11:33:42:
There will be about two gallons of oil throughout the tractor that will not come out when it is drained. If by flushing you are merely pouring something in the case and letting it drain out you not be accomplishing very much. If you use a flushing agent and run the tractor then about two gallons of whatever you use for the flush will be left in the tractor.
