Re: 560 Gas Engine
Posted by mike paulson on December 26, 2010 at 01:19:04 from (98.15.178.36):
In Reply to: Re: 560 Gas Engine posted by glennster on December 25, 2010 at 16:51:56:
an engine works at a certain air fuel mixture, if you say your pulling the choke back to make it run alittle better that means your restricting air flow , in other words richining the mixture to make it run good, this sounds like you have to adjust the air fuel mix on your carb, try that first before you rebuild your motor and see what happens, iffin the A/F is properly adjusted and you stop fouling your plugs everything might be dandy. but if your plugs are indeed being fouled with oil you do have a problem, you say oil corrosion which really doesnt add up?
post a pic of one of your oil corroded plugs.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
