Posted by mike paulson on December 26, 2010 at 06:03:29 from (98.15.178.36):
hey guy's i have change hundreds of tubless and split rimmed truck tires in my time using only tire pry bars, bead blasters and my favorite ether.
so i was wondering how one goes about changing 13x28 tractor tires. are they easily pryed over the rims and is seating the bead best done with ether or a blaster? or is it best to just put tubes in for easier bead seating. are there any other things i should know so i don't blow myself and shop up? oh there will be no calcium used...
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
