Re: Where to find ALTERNATOR mounting brackets
Posted by Bus Driver on December 26, 2010 at 07:12:29 from (67.213.39.62):
In Reply to: Where to find ALTERNATOR mounting brackets posted by RTR on December 24, 2010 at 09:59:13:
Using the original generator bracket for conversion on the 140 yields a result that does not look good and holds the alternator out too far from the engine. The factory base bracket 68 384 C91 for alternator is very expensive to buy at $258.31. Installing it almost certainly requires the radiator to be removed. I designed and built a compact bracket for my 140 while rebuilding the water pump and repairing the radiator. The conversion is easier with the open access. The alternator is held in close to the governor linkage. I have no pictures to post.
