Re: SMTA FRONT TIEDOWN FOR HAULING
Posted by kevinj54 on December 26, 2010 at 13:20:17 from (71.115.129.175):
In Reply to: SMTA FRONT TIEDOWN FOR HAULING posted by gene bender on December 25, 2010 at 12:36:51:
I'm sure that aircraft is a interesting field when you are trying to save weight and still make a long life unit.
The pipe welding stuff we do is all done to the appropriate ASME welding codes.
The bulk of standard pipe is is just schedule 40 or 80 carbon steel welded to a specification.
The food grade stainless and high pressure stuff is very specialized more like the aircraft welding you describe. We have to have weld coupons, weld mapping, welds stamped by the welder and of course record keeping.
I sub some work to a boilermaker and that procedure is a whole nuther can of worms!!!!!
