Re: B and BN narrowest track ?
Posted by Heat Houser on December 26, 2010 at 13:45:33 from (69.66.35.73):
In Reply to: B and BN narrowest track ? posted by Trent544 on December 26, 2010 at 13:08:30:
I use a B to spray my 30 inch rows. I have set the rear rims narrow and have maybe have 4-5 inches clearance both sides. (11.2-24) If you are wanting to spray taller beans, I would suggest a BN as you should gain another 4 inches or so.
Others may have to chime in with the width difference between a B and a BN.
Two wheel tricycle front and 11.2-24 rears is on mine. (I think 11.2 but memory is faulty)
The B is light enough that beans up to 6-7 inches tall won't be damaged, at least you cannot see it within a week or two.
As a point of reference, my cultivator books says that the B cultivator can be set to 32 inches.
