Re: IF1066 hydraulics issues
Posted by gbs on December 26, 2010 at 18:40:17 from (71.0.23.206):
In Reply to: IF1066 hydraulics issues posted by Ben at PCS on December 26, 2010 at 12:04:34:
had a lift cyl.on a disc that the spring retainer came loose inside the coupler it would and wouldn't lift,i thought something had come apart an was checking the flow of fluid, after being aggravated by it halve a day i finally noticed the ball in on one of the male couplers wasn't tight against the seat,tore it apart and found the spring retainer loose ,by it being loose it couldn't push the ball tight enough against the female coupler pin to hold it off its seat which made it check the fluid flow,though it was a major problem but turned out simple
