Re: Confirm Engine Size Suffix Code Questions
Posted by CNKS on December 26, 2010 at 19:13:07 from (216.144.104.128):
In Reply to: Confirm Engine Size & Suffix Code Questions posted by RTR on December 26, 2010 at 15:02:41:
Look at the old head gasket and compare it to the water passages in the block.If the holes in the gasket are a lot smaller than the holes in the block and it has a water pump it is a C123. If the gasket has large holes in it it is a C113. However the engine serial does appear to make it a Super A. If so the engine serial prefix should read FAAM. The year is likely 1948.
