Are the plugs being fouled with oil? If so chances are that your rings are worn and you are pushing oil past the rings. If that is the case the only real fix is new rings. If you are on a budget you could try to get by on the cheap. I don't like to do this as a rule but sometimes it will work okay. If the sleeves don't look to worn you might get buy honing the cylinders and putting in new rings. You would want to take a pretty close look at the rod bearing while you had them out too. I would also probably take the head to a shop and have the valves done.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
