Re: 656 Hydro rear end swap
Posted by IaGary on December 27, 2010 at 06:27:33 from (69.63.16.90):
In Reply to: 656 Hydro rear end swap posted by Ponyroper on December 27, 2010 at 05:28:54:
Unless you are thinking you want a gas for cold weather why even switch the fronts.
Buy the diesel and leave it together. Just run it till the engine goes bad then consider the swap.
Gary
