IH stopped using the original welded on bracket type tank not long after the stage 2 SM tractors started being built. Service tank was changed so that 2 bands and a bracket similiar to the air cleaner mounting was used. So you may find that type on some tractors that you can use with the bracket and bands. 400 and 450 D used the same mounting but the tank neck will stick above the hood more if used. Late SM and all SMTA used the same small tank retained by bands. Early M small tanks used a different outlet hole. MD tractors were built after the change. After the change the M and MD and a bunch of SM used the same weld on bracket tank.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
