Re: Cleaning gas system on an H
Posted by rustyfarmall on December 27, 2010 at 10:37:56 from (209.152.78.140):
In Reply to: Cleaning gas system on an H posted by gene bender on December 27, 2010 at 09:18:33:
No there is no way to clean the tank without first removing it from the tractor, and the best way to clean it is to take it to a radiator shop and have it chemically cleaned, or go out and buy a couple gallons of muriatic acid and do it yourself. Pay no attention to the guys that will tell you to just fill the the tank with rocks, strap it to a rear wheel on a tractor and drive it around for awhile. That is absolutely the WORST thing you could do to that tank. Common, ordinary teflon tape will do the trick with the sediment bowl. If that doesn't work, you have more serious issues.
