Re: freeing up stuck engine
Posted by oldiron29 on December 27, 2010 at 14:37:08 from (69.112.87.249):
In Reply to: freeing up stuck engine posted by Fallon on December 27, 2010 at 13:42:25:
Fallon, I have used 50% AFT and Acitone. Or ATF with PB. If it is dry stuck it will work in a week or two.
If it is water damaged It's more difficult. Most times you have to pull head and pan remove rod caps. Than smack the pistons with a block of wood. You should pull pistons and clean rings anyway. oldiron29
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
