856 Clutch pedal pivot shaft ?
Posted by jd720 on December 27, 2010 at 17:46:20 from (66.38.124.33):
Does the clutch pedal pivot shaft just screw out of the housing or is there a nut on the inside ? Need to build it up to get the play out of the pedal can I get it off without taking the top cover off ?
