With the standard 3-1/4 inch long pipe nipple under the cap I remember 9.5 inches down as the original level. Could measure one when out to make sure. If using the standard fill vent opening on the liftall, you may want to install a short nipple and a 1/2 inch pipe tee on the drain opening and then route the return line from the operating valve to the tee. Install the drain plug in the other opening of the tee.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
