I would change the hyd filter before adding any of tha expensive oil.If that large pipe plug is out you may want to make shure the bolt in back of it is tight? Said bolt holds the gear in place that drives the gear on your hyd pump.After you CAREFULLY reinstall the filter the suction pipe to the pump may need to be resealed?? We used a Yamaha sealer called Yamabond and it worked very well!! I have learned much here!! Bud.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
