Re: Farmall H hydraulic level
Posted by DanR on December 28, 2010 at 07:50:08 from (67.236.8.213):
In Reply to: Farmall H hydraulic level posted by LloydE on December 27, 2010 at 21:48:54:
I have the original system on a M and it does have the brass valve on the fill cap. Original 2 way valve and quick disconnect. I agree that a raise in ambient temperature would increase the pressure slightly in a closed system. However when the temperature returns to 'normal' it cannot have a vacuum if it is indeed a closed system. If you have ever used the quick connect you know that a small amount of oil will be lost which I think would tend to release any built up pressure. The only thing I'm sure of is you will get your hands dirty. :P
